1 - 15 of 15 Posts
I read this sticky with interest. What xactly doesn't do for you and when would you need to do this? Sorry. Am a newbie with Vics.
you have to tell us what year and model you have first
There isn't a throttle point reset on the newer bikes.
Per Kevinx, one of the best Vic wrenches around
"Does not apply to 08 and up bikes"
Hmm interesting, I have a 2012 xct. It's cammed, pcv, and tuned by the doctor. Tonight she stalled out when I stopped at the end of my road and then stalled four more times before I could get in a position to investigate. Did the tps reset per the instructions in the sticky and she's idling smooth as silk. This is the second time in the last few months I've been forced to use that method now I'm thinking I'll just do it randomly maybe each time I change the oil and lube the clutch cable. I'll have to give Kevinx a call Monday and see if he has any idea why she's doing it, maybe a loose wire or something.
It does not state in the sticky that it is only fot the earlier bikes, and if it works on PCV, would be nice to alter the sticky then ??
Key on, switch on, engine off
Slow 5 count rotate throttle from closed to wide open
Hold throttle wide open for slow 5 count
Let throttle SNAP shut/closed
Cycle kill switch (off then on)
Start bike, and enjoy the ride
This is what I tried tonight! It seems to have done something. Maybe it's my imagination. I have a 2015 XCT and it's been sucking down gas. I hope to run into KevinX down in Daytona where he's set up and I'll ask him this weekend. Now I'm confused and not sure what to do!
In doing the old TPS reset on 08-up. You inadvertently do a IAC relearn type procedure. When IAC voltage out of range, bike will idle strange and even stall out.
So this procedure for a 08 and up will affect the Idle Air Control?
If I have a high idle issue, could this be worth a try?
The bike seems to run great for me. No issues with response or anything
Sent from my SAMSUNG-SM-G870A using Tapatalk
Typically for erratic idle.
Try looking for vacuum leak in your case.
It seems to idle lower. I have been averaging 150 miles per tank and a buddy following me said I smelled of raw gas.
Kevin....I am going to try to come see you this weekend. All of this started after my first oil change at the dealership. The bike is a used 2015 Cross Country Tour with no known mods.
1 - 15 of 15 Posts
