1 - 3 of 3 Posts
Ok heres the deal. my 09 Pin has the stage 1, Im replacing the swept pipes with the Thor(if they ever come in) and I have the VFC3.
Is it worth it to spend the 200 for the dyno? RPW states you need the stage 1 download for the pipes. I got that. With Lloyd's help my VFC is pretty much in.
I was debating getting a Air/fuel meter to zero in my tune, instead of dyno. I have access to an emissions machine that I used to set up my carbs on my Royal Star, so I can set the VFC green circuit that way.
i wouldn't think you would need one if Lloyd told you where it needs to be set at. unless you are a "if better is possible good is not enough" type of guy. then you probably wont be satisfied until you get the dyno.cheers
Well I havent done cams or anything like that, I think I was planning on the Dyno for the need to know Hp and stuff. I guess Ill get a nice a/f meter and work with that. Ill dyno if I ever do major upgrades
1 - 3 of 3 Posts
