1 - 20 of 29 Posts
Does anyone know the symptoms of a torque compensator that needs to be replaced. For a 2008 vision. 106
If it sounds like a bucket of bolts in primary while at idle, and the sound goes away when you pull in clutch..........That is compensator.
Reactions: normthenomad
Hey Noe! Good to see you are still around! :)
Yep. What Noemtz said. The compensator doesn't necessarily need to be replaced though. Could be just a matter of replacing a wave spring.
Thanks.....Still here. Check in occasionally, been real busy.
there is no way to replace the the spring and washer. you have to buy a complete one
if you had one in your hands you would know they don't come apart
Torque compensator does come apart. I have actually just upgraded a 2012 version with a 2013-up version. So yes I have had them in MY ACTUAL hands. More concave spring plates and washers in newer version over 2012 and older.
Before and after pics added.
Discussion Starter · #13 ·
Thanks
Thanks guys.
I have an odd thing happening.
I thought might be the compensator slipping under heavy load.
By you discription it doesn't sound like its my problem might be something else.
I might take it apart for inspection though.
Thanks guys.
If it's slipping it's the clutch failing. Go to Lloydz and get the Barnett clutch kit.
Drivetrain & Clutch, Lloydz Motor Works
Better yet; give him a call to get his advice for your particular bike and situation.
Discussion Starter · #16 ·
Thanks
No sound.
I thought it might be it slipping under load. Symptoms I have are only under this condition.
Rpm around 2800. Then under hard acceleration the bike almost feels like it's bogging. Then around 3600 rpm it feels like 4 barrels kick in. If you know what I mean.
Already changed
Plugs
Plug wires
Checked fuel pump
Battery wires
Was thinking that the cogs on the compensator where just not right enough and moving under heavy load
Doesn't do it on wide out throttle from a stand still or when I have the rpm in higher level in gear.
It would be extremely rare for a compensator to fail in any way. All Vic compensators sounded horrible at idle clutch out; previous to 2012
Yep. For that reason alone, worth the upgrade.
No sound.
Already changed
Plugs
Plug wires
Checked fuel pump
Battery wires
Look for vacuum leaks.
My buddy booty68 has a Barnett clutch in his XCT , I rode it and WHAT A DIFFERENCE !!! I want one , my clutch feels like mush compared to his ....
1 - 20 of 29 Posts
