21 - 29 of 29 Posts
No sound.
I thought it might be it slipping under load. Symptoms I have are only under this condition.
Rpm around 2800. Then under hard acceleration the bike almost feels like it's bogging. Then around 3600 rpm it feels like 4 barrels kick in. If you know what I mean.
Already changed
Plugs
Plug wires
Checked fuel pump
Battery wires
Was thinking that the cogs on the compensator where just not right enough and moving under heavy load
Doesn't do it on wide out throttle from a stand still or when I have the rpm in higher level in gear.
You could be just in töo high a gear when you nail it.
Try going back a gear.
Will the upgrade work on all Freedom motors going back to 2003?
That's about my only complaint on my 04 KP. I don't pay much attention to it because my ear is used to it but I think others do.
Verify part #'s from 2012 down.
11 and up only
Hi, I have 2010 jackpot 106, trying to reduse backslack on engine while riding
Purchase late engine 2x belleville spring 0.9mm (7043638)
and space washer (7556577)
Do I need to purchase later model Retainer, Compensator?
Original 2X spring hight 18.6mm.
What max spring hight Im allowed to go to?
If I add purchased belleville springs and washer 6.4mm to my original 2springs hight it comes to 25.00mm it's that will be ok?
2X original springs and space washer makes 20.00mm
2x original springs and belleville spring makes 24.00mm
Which combination I should go with.?
Thanks for your help
Note that this is a very old thread you've necro'd, and many of the participants are not very active any more. I wouldn't hold your breath waiting for a reply to your question.
21 - 29 of 29 Posts
