Yeah that's what I'm gonna do, double check everything. Make sure there's nothing out of place. I recapped the nipples on the tb not too long ago, the old rubber caps were gone :crzy:Sounds like you got my kinda luck. Yea I would double check connections and all that...but also make sure those little rubber nipple things are on the the throttle body and it aint sucking air.
I looked up both intakes, they look very similar. I wish I could meet whoever owned the bike before me. I have many questions for himIf i'm not mistaken that airbox/filter is off of a 99 v92c. My mechanic told me that to get the best bang for my buck, to get one of these setups to replace my box with the tubes. Says it breathes better. Obviously a big sucker with a power commander is better....
NAPA hey??? Let's see if they got an outlet in Australia....Periodic TPS calibration is not required. If you replace the TPS it should be recalibrated. You can replace the TPS on your own & see if it cures your issues, you'll need a digital wrench (dealer) to make any adjustments. You mentioned your battery terminals are tight-what shape is the battery itself in? You can get a TPS at NAPA
part # 2-19187, Victory doesn't have a part # you have to get an entire throttle body.
Where's the MAP sensor?I think it was the broken wire at the map sensor that was causing those problems. After I fixed that and put the old tps back in, the bike hasn't given me one problem (knock on wood). Hasn't stalled, pulls strong, no more rough spots. Just figured I would put that out there in case someone else has a similar problem
What hasn't mate?Hasn't been around for a few years MBX.
ThanksGhost Rider. Just pointing out this is a 9 year old post and he hasn't been seen in three years. Didn't want you waiting for an answer. The Byte guy even longer.
MAP should be under the tank between the cylinders.
It would have been in the stock airbox.Thanks
Does it matter how old the thread? ... if it's on subject ,
(TPS replacement is the search I did ), and gets an answer?
I'll do a search for MAP sensor then see if I can get a specific location for it...
