1 - 5 of 5 Posts
2011 cross country wont crank over battery is good?
2011 cross country wont crank, acts like battey is low but battery checks out good, any ideas ?
Hi and welcome to the forum. What does the battery voltage show while you're trying to crank it?
I dont know,havent checked that ?
You might want to check it. Battery shows its true colors under load. If it's around 12 Volts while you're trying to start it, then you can eliminate the battery as the culprit. It might be the easiest suspect to eliminate off the list. Fuel pump would be my second suspect, but I wouldn't mess with it until you can confirm the battery's good under load. Test it, and let us know.
Speaking of fuel pump, when you turn on the ignition, do you hear the fuel pump priming?
Do you have headlight? Does it dim when you push the button?
If it doesn't dim I mean very slightly then you might have loose connections. Is your kill switch on?
If you have good battery check connections at starter relay its a gold color round piece behind the battery.
1 - 5 of 5 Posts
