1 - 10 of 10 Posts
Have a 2014 xc. About 19k miles. Just started having issues with the transmission. While riding I. Any gear, if I try to accelerate it acts like I dropped it into a lower gear. Even the rpms jump up. I have notice a loss of power as well. Any suggestions?
Any chance the clutch is slipping? Do you have some freeplay in the clutch lever? A lack of freeplay could easily cause a slipping clutch and the problems you describe.
I agree with Vinish...seems like a clutch issue
Does not seem to be any play in the clutch, matter of fact it engages almost as soon as I touch it now.
Oh wait that's what you meant by a lack of free play. So I need to listen the clutch cable a little!?
You need to read your manual. Motorcycles need more attention that filling the gas tank--a lot more attention.
Sounds like you are on the right track. Loosen the clutch cable to give you a small amount of freeplay and see if that solves the problem.
That's the mistake we make with mechanic answers. We assume the people complaining know which end of the screw driver to use. I'm still shaking my head about the people who never check their shock or Tires for the proper amount of air and complain so loudly how bad the bike handles or they got short mileage on a perfectly fine tire that now has the steel belts showing through. . .
Even if you are klutz with tools, manuals for anything should be read, be it cameras, phones, toasters, and vehicles - especially vehicles.
1 - 10 of 10 Posts
