1 - 20 of 51 Posts
Greetings,
I just noticed this today as I was cleaning my XC. I looked in the manual and it says that there is a connector for a battery charger/tender but it doesn't say where on the bike. Is this the connection? Can I plug a battery tender Jr. in this connection or do I need the victory charger?
[/URL][/IMG]
Thanks you in advance for the help with my questions. The weather is turning in Nebraska and the bike may be sitting for a few months before I can take it out again. I would love to hook a tender up to the battery. On my last ride I wired a pig-tail to my battery and also used it for a 12-volt charger connection. I was thinking I was going to need to do that again for my XC...but to my surprise...maybe not! :rolleyes:
On my Hammer it comes directly from the posts on the battery, its a pigtail maybe 12" long, connects directly to a tender jr.cheers
On my XC it is all the way to the front of the bike.
Is this a better angle?
[/URL][/IMG]
Hard to tell from the angle but yes, that looks like the same type of connector. I bought a Jr and connected it to my Vegas so I am sure that will work just fine cheers
This plug was on your bike when you bought it? That totally looks like a Battery Tender plug!
That's it Scotchie. Its called an SAE connector and it runs directly to the battery. Feel free to hook up an automatic trickle charger to it.
Awesome! I wish I knew this was there, I've killed the battery twice by leaving on my auxillary lights and had to clip jumper cables to the solenoid contacts and ground. lol
You may not have one. It comes with the bike in a separate container and is to be installed during the dealer prep. Some dealers leave them off for whatever reason. If you (or any buyer of a new Vic) don't have yours, tell your dealer you want it--its part of your bike.
Like the others stated that's the Battery Tender harness connector. For those with the Cross Country and Tour models (or anyone that has added a 12V power outlet that is hot all the time) the cleanest, easiest way to plug in a battery tender is with Battery Tenders cigarette lighter adapter. I was going to install the sub harness to my battery until I saw this.
http://batterytender.com/cigarette-lighter-adaptor.html
Tech23
Tech23
I agree with Tech23 almost completely, but that's what makes the world go around, and so forth. The adapter is a fine idea, and the one he refers to is cheap enough. Powerlet makes another one (as I imagine many companies do): http://www.powerlet.com/product/cigarette-plug-to-sae-cable/2 . That's more expensive, but I've been using Powerlet products for a decade or so, and I can attest to the grade-A quality of their products.
Me, I think the most convenient plug-in system is the one I made by drilling through the left side cover. My write-up on this is in this series of photos and captions: http://www.billanddot.com/victory-xct-powerlet-in-side-cover/ . I put a female Powerlet socket in the side cover, which I use for heated gear and for my battery tender-like device; on that, I replaced the SAE end of one of the cords that came with it with a male Powerlet plug. But that's me...
Is that just for XC or all Vic's? My Jackpot came from a dealer trade & did not come with it.
You got me there, Larry. I know they are standard on the Cross bikes, but I have no clue about the other models. Anyone out there know? Anyone? Hello...anyone there.
Ric: with all due respect -- and as the completely satisfied owner of one of your lay-down license-plate brackets! -- I'm not convinced that the SAE plugs are standard on any Vic. I think maybe just some dealers do this on their own, as a courtesy to buyers.
Did you come across some reference to the plugs in an owner's or shop manual for the X bikes? If you did, that would convince me; if you didn't, well, my "courtesy" theory might be correct. Or not.
1 - 20 of 51 Posts
