anyone know why the turn signal indicator bulb would not illuminate yet the blinkers still work fine?...first thing i did was change the bulb but still nothing. 2005 vegas any help would be appreciated
Try checking the connections in the headlight assembly. I recently installed the digital speedo and had the same problem you have. After checking everything again I found a loose connection. Hope this helps!
i took it all apart no loose connections. i pulled the bulb and put a multimeter on it and its got power so the socket has to be bad or bad connection. i used a bulb from another indicator which i knew worked so it cant be the bulb.
1 - 3 of 3 Posts
