1 - 2 of 2 Posts
Need help. My right turn signal has started to act up. When first started both signals work fine. After a few mins of riding the right one will not work. Shut the bike off and restart and it will work. Then same thing again. Can someone tell me what wires going down the right side neck are the signal wires. Possible short Or could this be the signal module flasher.
did you try turning it on while it is running but NOT out riding. just idling? my thought is you have a lose wire and movement is causing it to lose connection. I had the same thing happen to me but on a different bike.
1 - 2 of 2 Posts
