Hmm. I;m not sure about that. Gasoline has specific qualities, regarding combustion and burning. The higher octane rating simply slows the fuel burn rate inside the cylinder, to allow a higher compression ration. A faster burning, lower octane rating gasoline has the same calorific value as a simliar quantity of high octane gas. The problem with the fast burning gas is that it’s likely to detonate at higher compression ratios, or preignite due to temps and pressures in the combustion chamber. The old trick used to be in carburetted bikes, if you ran a higher octane fuel, you had to advance the ignition timing. And vice versa if you you were using lower octane fuel. So, the higher octane gas burns slower, which is what you want, to get the optimum combustion at the optimum piston position. It’s the expansion of the burning gases that provide the power.
When we talk about faster and slower burning fuels, we are also talking about very short time intervals. fractions of seconds of difference in the buran rates of regular compared to premium.
I have the Lloyds timing wheel on my Vegas, and I have it set to plus 4 degrees of advance, as others have done most of the research and plus 4 degrees of advance appears to be enough. Victory set the timing advance from standard, to kick in at 2,500 rpm, if memory serves me correctly. They didn’t want any additional advance until that speed. However, 2,500 rpm on my bike in -6th gear, is I’m guessing around 80 mph or higher. We don’t usually cruise that fast, and with putting the timing wheel in, and giving a mechanical timing advance of 4 degrees, we get the advantage at lower rpms. In fact, from take off. I suspect Victory had some conditions where the spark advance just didn’t do well, so their solution was to limit any advance until you were at higher rpms. But again, they are building the bikes for a wide range of operating conditions. Few of us might ever experience the situation where more timing advance would create a problem.
