Okay I'm curious what are these seemingly random connectors next to the ABS unit on a 2012 CCT?
Obviously never been used lot of corrosion.
I'm finding lot of unused connectors all over this bike this is just the latest.
The location is so inaccessible I don't know what would use this.
I have a 2012 CCT and when installed the saddlebag audio system I ended up using a couple of the unused connectors. Frankly I was impressed at how the main wiring harness was already made for some accessories Polaris only made available long after my 2012 was put together. The rear speaker amplifier mounts under the rear fender near the ABS unit.
Hmm so is that what those connectors are for?
Just seems an odd place to have exposed connectors unless the prior other removed whatever was connected back there.
You also have a 12VDC switched two wire female plug under the tank along the front left side. It's in the main harness for the driving lights kit for the CR. I used those wires and a switch on my CCT dashboard to power the coil of a relay to power my CCT driving lights.
The switched 12VDC in the saddlebag was for the CC, not the CCT. But if it's another switched power connection it would work just fine to add a power outlet to the saddlebag.
The forward thinking went pretty deep with the engineers who designed our motorcycles.
I don't know so much that it was forward thinking but cost savings. You build a frame with a harness and the final product can be whatever demand requires.
Switched power would be good for a relay. The kuryakyn light kit uses the heated grips connection in fairing to trigger relay so only power when engine running.
Hello all!
I've got two seats for my XC - a touring seat and a tooling around town seat. Does anyone have a recommendation on storing the seat not in use? I have a bracket for the tour pack that works well for that, but I was wondering if anyone had a ready made bracket for hanging the seat...
Hello fellow vic lovers,
Decided to pull the trigger yesterday on a mustang vintage seat with backrest for 350.
Who has it and what's your take. I knew I would not like the stock seat and I have never liked any one of the 6 I've had on different bikes. I usually just go to KnoPlace upholstery...
Today my cruise control stopped working. While travelling at a constant speed in 5th gear at about 55 mph, I pressed the "on" button. I got the momentary green flash of the cruise icon on the dash like normal. I then pressed the "set" button and nothing happened. The green cruise icon did...
Got this idea for a new thread based off comments from another thread.
So what is the farthest you have ever ridden for something trivial?
This is where you started your ride saying I would like this and you rode to get it.
Mine was an approximate 135 mile one way ride to get a piece of apple...
Hi all. I'm looking at upgrading the factory head and fog lights on my 2013 Cross Roads. I'm going to go with a JW Speaker Adaptive 2 headlight, and also want to go LED fog lights. What size fog lights would I need to get to still use the factory housing, if possible, or would I have to replace...
