1 - 4 of 4 Posts
The Owners manual says not to pull trailers with the V92C. Any of you know why? What's the weak point in the machine that won't allow it? Is it the recommended tires? Maybe the drive belt? Are the bearings too small on the swing-arm? Maybe it's the output shaft problem. I wonder if the issue is resolved if it's upgraded?
Any of you pull a trailer? If so, have you found any issues?
Thanks for the help,
Standard liability disclaimer-I don't believe any motorcycle manufacturer would tell you to pull a trailer-they are not engineered with that in mind.
Having studied engineering, honestly, that was my first thought. I'm glad someone else came to the same conclusion.
I plan to study hitch designs from other cruisers and Gold Wings, then see what I can whip up.
1 - 4 of 4 Posts
