1 - 8 of 8 Posts
Hi ,
Just bought a 2008 Kingpin with a VFC III already installed. I notice that the exhaust oxygen sensor is still connected. Shouldnt the oxygen sensor be disconnected as part of the VFC install?
Tks
Hi ,
Tks
According to the installation instructions the O2 sensors should be disconnected.
Yes, what blueracer17 said. Disconnect the stock O² sensors, and leave them disconnected. The VFCIII does not use the stock O² sensors (or any O² sensor for that matter).
Do you mean the 02's are still in the pipes (thats ok )
or are then wires un hooked. Most guys just un hook the wires.
You might have to re map the VFC now
it's stil in pipes and still hooked up. Does the vfc just not use they or will it not work as well when the o2 sensors are hooked up?
the computer still uses them so if they are plugged in the computer is trying to tune also, unplug them !
1 - 8 of 8 Posts
