1 - 14 of 14 Posts
Help us help you
Help us help you. When does it vibrate?
You don't KNOW vibration. LOL
Victory has vibe reduction down to a science. Go ride a Harley.... ;)
But if it's still too much for you, get ISO grips and ISO pegs.
Yes to owning vtwin. Its my third victory.2nd cross country. All gears above 2000 rpms Thanks
Is it very noticeable compared to your previous XC or just a bit more? Once the break-in period ends, the bike gets a bit smoother, and the move from your previous XC the current might have brought that difference to your attention.
Ever ride a Kawi? My old Meanie looked like a couple of paint shakers at idle, but ANY throttle and she was silky smooth!
Does it only happen under acceleration? Or also while at a set speed? The way the bike is put together is pretty different than most bikes being the engine is actually a part of the frame. As such, you'll feel vibrations under acceleration, but should smooth out at speed.
Go to the dealer and have him ride it. You might need your wheel rebalanced.
Maybe there is more to it then you think.
I'm sure a dealer will test ride it for free
Vibrates in all gears at 2000+ RPM; does it vibrate in neutral at the same RPMS?
Does the vibration increase/decrease while moving at 2000+ RPM with the clutch pulled in?
Does it vibrate more/less during acceleration or does it vibrate the same while cruising as it does while accelerating?
the question should be is why the big diff in vibration between the cross country and vision. sometyhing is wrong.
After the first 500 miles, the vibration on mine settled down. But it was never even close to what my Ultra Classic did with rubber engine mounts.
I know you say 2000 RPM but maybe you could gauge it by MPH. If it is a specific MPH, it would be a wheel weight fell off. If it is only gauged with RPM, does it do it standing still?
1 - 14 of 14 Posts
