1 - 1 of 1 Posts
I had the bike up today to check and grease the suspension bushings.
Back track a sec, I had previous noticed that if you grab the swing and move it up and down, there is noticeable play.
Not sure if that is normal, I didn't noticed any inspection process in the manual like that in the manual.
Is that normal?
Some other oddness to me. While under the bike, and I had the links out. The shock was able to shift left and right. Im thinking normal on that too.
Once I had the links out. Only the forward bushing could be removed to grease. The rearward one looked it was a heim(sp)joint and couldnt grease that one.
1 - 1 of 1 Posts
