1 - 20 of 28 Posts
I saw this video in youtube on how to improve the security of our saddle bags and to keep it from falling off the bike. Take a look at the stock fastener. Two of them on each bag. Am not going to trust it to hold a full load. The guy who made the video suggests using a speed u bolt along with bolts and lock nuts to secure the bags.
https://youtu.be/o53wTkzrWOg
i had mine for over two years, 25,000 miles, never once did my bags come loose, even when i wrecked it, the factory fasteners pulled through the bags and were still attached to the bike.
Glad this has worked for you DTMMIL. Maybe my fears are unfounded. Wanted to be sure. Besides, it's not often I'd take the bags off unless am cleaning the pipes.
No issues with mine either ... I've had my bags off many times .... :eek and always have a full load ....
nevermind,,,
I installed those U-Channel speed nuts on my CCT soon after getting it. I'm going back to the oem 1/4 set-up this winter. The U-Channel speed nuts simply don't have near the surface area for retention as do the oem 1/4 fasteners.
I've been using the "fix" mentioned above for almost 3 years now except I just replaced one fastner on each bag instead of both.
I went to the 5/16 Speed nut and bolts shortly after buying mine and I've never looked back. The local Lowes had them so what the heck, that's pretty much the only reason I have ;) . They're pretty secure. Whichever method you use just be sure to check them, any method can fail.
The Dzus 1/4 turn fasteners are all over aircraft and I've been popping those for 35 years so I trust them. My only two complaints with the bolt setup is you have to be careful putting the bag on to be sure it's straight and you need a wrench to remove the bag.
I picked up these - click here
It takes an extra couple of minutes when I check rear tire pressure, but that's a small price to pay for peace of mind.
you can get all parts at hardware store
A: 4 Threaded 5/16 black coated U-Clips
B: 4 Stainless Steel Flat Fender Washers
C: 4 Rosette Thumb Screws with Stainless Steel 5/16 2" Screws
use what ever you want for bolts. Ask hardware store guy about a wing bolt
So you fixed something that isn't broken or a problem?
14k miles, overloaded on my 3700 mile Sturgis trip and no issues.
I have found my quick locks loose on more then one occasion , I added one Brukus fastener per side in the front of the bag for added security . There are older threads here of guys bags flying right off their bikes on the freeway . Its simply added bag security . I would like to thank PaiN for providing me the hardware at no charge , thanks Brother .
Harley use exactly the same system.
The bags on my Road King have never looked like coming loose or falling off in 150,000 kms so I wouldn't worry too much!
Russ.
I don't guess you noticed that I put fix in quotations. No, I did it because I never had a problem but others had when I joined this forum over 3 years ago.
1 - 20 of 28 Posts
