1 - 4 of 4 Posts
Started out late last year with a speedometer/check engine light problem, 1yr and now worse than before. Couldn't even get out of the driveway before the check engine light came on, no turn signals work. Took another look and replaced speed sensor again and now won't even start........arg.
I've made it worse than before and wish I'd have taken it in, way wah.:crying
You didn't mention what steps you have taken .. Back to basics, Clean and tight battery cables (this will cause check engine light to come on) low battery voltage. May be time to take in to a shop.
I just came from the garage and needed to wah wah a bit. I am no longer looking for help here. If it was going to happen, it would have happened by now. My previous posts are available if you are curious.
Thank's roso154 for your interest though.
Glad you got the wah wah out of your system. Use the vast store of knowledge on this and other forums to parse the problem into a manageable size and make riding enjoyable again.
1 - 4 of 4 Posts
