1 - 3 of 3 Posts
I need to have the mounts for my sidecar rig tack welded in a couple of places.
Because the sidecar is attached to the bike - 2003 V92C - I'm wondering what aside from disconnecting the battery and ECM I should do prior to welding.
Specifically, do I need to completely remove the ECM module from the bike's frame to prevent damage or just disconnect it?
Thanks!
This might be a bit late, but better safe than sorry.Remove both battery cables....negative first and disconnect ecu and remove.Not a hard job.Reverse for assembly.
Welding
Also make sure that you ground very close to your weld zone and make sure that you do not ground through a bearing without a jumper.
1 - 3 of 3 Posts
