The single wire is likely the hot for heated grips, the other doesn't look familiar I'd have to check wire diagram.
All should be labeled with white tags on them if you are looking at it from the other side.
At least that is the case on my 2012.
You'll find several unused connectors in fairing depending on your bike options.
At the neck on other side just in front of gas tank you'll see unused connector that goes to a cross roads model driving lights.
At the base of engine area a triangle connector unused that is for kickstand switch.
Under right side cover an unused connector for CA canister thing, unless you have a CA bike.
At rear of bike if you don't have a 12V power plug in the right saddle bag, there are two unused connectors for that purpose tucked up under rear fender.
Under left side cover down low is ECU connector.
Same area up higher should be trunk connector, but might be under seat, several pins on it.
Under seat at rear is two pin plug for heated seat.
