1 - 15 of 15 Posts
I had my bike torn apart pretty good this past week for new tires and some upgrades. It is a 2012 Vic XCT. Under the front left lobe of the tank sitting on the left side of the frame is a large wire connector. This has a ton of wires running in and out of it. Right next to this big connector is a small connector that is not connected to anything. Does anyone know what it is for? Below is a picture of the big connector and the small lonely connector who has no mate.
G'day,
Vinish
Small connector is for driving lights - it's also a good source for switched power if you want to run something else off it.
Awesome. Thank you very much. As usual, the Victory Forums comes through.
G'day,
Vinish
I'm going to have to remember that is there.
Is it switched power or always powered ?
ammo_umb said specifically that it was switched power. I have no interest in driving lights so did not test the connector when the tank was off so can neither confirm nor refute ammo-umb's comment.
G'day,
Vinish
G'day,
Vinish
Ahhh , I missed that one . Thank you Vin .
I started second guessing myself so I double checked this morning - bike switched on, driving lights on - bike switched off, driving lights off.
Crimp blade connectors to your wiring, plug them in, and electrical tape them.
That right there is for heated toilet paper young man LOL
Connector
Does anyone know what the connector model # is this would plug into?
I would like to know this too!
I spent WAY too much time this past weekend trying to find the mate to that Delphi connector.:crzy: If I can't find it soon, I'll just cut off that connector and put on a different one. I hate cutting wires and splicing into my harness. I prefer to use the same style connector and create a plug-n-play type setup. I like the ability to remove the "add-on" if I need to down the road without compromising the existing wiring.
If someone finds the mate to this connector, please share!
Another alternative that allows for a quality, clean install and usually cheaper in the long run is to get some waterproof automotive connectors off eBay and swap out the stock one. Something like this or similar: 5 Kits 2 Pin Way Car Truck Waterproof Electrical Wire Connector Plug Terminal | eBay
Shop around for the correct gauge connector.
1 - 15 of 15 Posts
