1 - 11 of 11 Posts
Before I ask this question, I KNOW what the manual says but I would like to know what you all are using. I ask this because yesterday I accidentally put 87 in my XC. But the bike felt pretty much the same and ran ok. I have heard using a lower octane is ok, and may actually help the engine to run cooler. Your comments/experience is appreciated.
If the bike doesn't knock it's fine.
Is your bike stock?
It is actually better to run as low of an octane that is possible without any detonation/knocking. A higher octane than needed can promote carbon buildup in the cylinder and eventually could cause detonation and overheating.
I use 89 octane all the time. In morticians I use 91 octane.
Kevinx say Vic say use 91 cause there are some that would use 87 in the morticians or in the desert. He even says you can use ethanol if your going to use it up the hole tank in one days time.
download puregas app to find good gasoline station
I use high octane Unleaded exclusively (non ethanol)
Done 60,000 miles.
About to go inside the engine for a gearbox repair so I'll soon see how much carbon is in there.
My XC has Vic stage one. Been using premium since new but if I can use lower octane I would like to see if it would help with the heat. It is already in the 90s here in Biloxi with high humidity. We'll see how this tank works.
ok gotta ask.. What's a "morticians" that uses hi-test? And if you use 89, I'm sure gonna start. I've used 91 and occasionally 94 since I bought my XC in 2012.
My guess is its auto correct for mountains
@Tarzan...then I'll have no worries it'll be clean as a whistle! :)
1 - 11 of 11 Posts
