1 - 3 of 3 Posts
Could someone please tell me the size of the socket I need to remove the passenger foot peg bracket on my CR. ?
I am doing a starter replacement and I don't have a socket to fit those bolts to remove the exhaust.
Thanks.
Probably 24mm Ritchie. I say probably, because it's that on the left hand side, and the right hand side looks the same, but the socket isn't going in there unless I take the heat shield off the muffler, and its 10 o'çlock at night.
ObiSteve,
Thank you very much for the information and 24mm was exactly correct. You made a very long job go a lot better. I can't believe how much stuff I had to remove to get at that starter.
The new starter is in and I have started putting things back together. One twisted off bolt so I will tackle that tomorrow before I work again on re assembly.
I sure hope the new starter works and I have no exhaust leaks after all this work.
1 - 3 of 3 Posts
