1 - 20 of 20 Posts
I bought blue wrap on Amazon. Still haven't installed it yet and unsure if I'm going to lol
JP Cycle has a few choices. Check on the web for install some say put it on wet
DEI Titanium wrap , no spray silicone needed , no need to soak in water first , easy application . Lasts forever if you wrap it properly .
Wrapped my shotgun pipes with DEI off amazon. worked well.
Ran into a guy on a trip through Nevada who said that eventually the wrap will crystallize the metal pipes and cause them to crack....
Makes a little sense to me with rapid heating and cooling cycles to cause stress cracks in the pipes, however I think it would take a very long life of cycles to cause issues.
Never heard of that before ..... :crzy:
Bought DEI Titanium wrap, and installed it not on my Vic but on my friends HD as that pipes looked like C&#$P
easy to install, the forum members helped me with instructions, copied below;
http://www.victoryforums.com/showthread.php?t=88946
read and enjoy....
So, now the big question. Is it possible to wrap the headers on XCT without removing the pipes? Looks like a lot of close clearances... Not feeling ambitious enough to unbolt a bunch of stuff...
Only one word I can think of Broggs ..... No ?:crzy:
Dear broggyr, you did not read the link i posted, hahahahhahahahahaha
:ltr:
Anyway it was a 1 day job removing and wrapping, and replacing all the galvanizing bolts with stainless etc no biggie
:D
I did skim through it, but figured I would ask because I didn't see anything referencing the XCT. However, if you had to do all that on a steel-framed bike then it would probably be even worse for me.
Of course, I'm such a lazy bastard, I will work extra hard to find an easy way lol
+++++ 1 thumb up
totally understandable, hahahah :rolleyes:
Thanks for the info! I just ordered DEI titanium from Amazon. 2"x50' for $42 plus free shippingthumb up
Don't forget your ties , you will need 8 of them !cheers
Take your time and wrap even and tight. It looks great when it's done. Mags gave me advice when I did mine. Thanks buddycheers
Anytime , help you any way I can Brother !cheers
death wrap!
sooner or later your pipes will die when wrapped. too bad they are not at least 304 stainless as it holds almost 3 times the heat in the pipe + would withstand wrapping longer. read where its very important not to overlap too much which will kill the pipes sooner. also its reported its impossible to clean. ti thought about wrapping under the heat shields as little is seen + when the pipes are done just buy another set
And I thought that I was the only one LILMAG helped out.... thumb up
There is a lot of info on this site, but you have to filter out the experienced persons..... who actually already done it, and not dreamt it.
:D
wrapped + dirty
once wrapped pipes get girty + oily they stay that way, kinda like a well used garage rag around the pipes. 304 stainless is by far the best exhaust material, wish someone made a 2-1 system for my hammer from 304 stainless.
1 - 20 of 20 Posts
