1 - 15 of 15 Posts
always thinking about what my next aftermarket item
will be for my jackpot,looking at primary,and derby covers
but can't make my mind up on what to get (lots of selections).
then maybe fly bars,rad controls,sissy bar,fuel tuner the list
seems to never end.. sometimes think just how much money
you could spend on aftermarket parts for these bikes?..
:crzy:
Bars!!! Carlini Menace 16's. My next and fairly close to final project. Some "real" apes for the Hard-Ball. :)
But I do have some VictoryHID lights I've yet to put in. Better get it done.
1) Pipes - what the "Hotrod" exhaust, but was told it will not fit without making a mounting bracket (which should be no problem) and a tuner which goes hand in hand with pipes
2) mod the stock air box and install a high flow filter
3) paint my wheels, lower forks, and primary cover
4) passenger backrest (AKA sissybar) and install the passenger seat. This mid will more than likely be completed before any of the others since I am making the backrest as I type.
5) vertical tag mount. (Also in the process of making).
The big 3!
:crzy:
You may be running way lean if you are not running a fuel controller ... Be careful .
Quarter turn and led headlight...:) Pending approval from the warden..:eek:
I have an ez-clutch and 1/4 turn ring sitting on the bench waiting for me to install.
I also am thinking of getting the Doran TPMS and Centrimatics wheel balancers.
Maybe more vids..thumb up
2015 things to order for Jackpot, pfffff ok
1. Tachometer
http://www.powersportsnetwork.com/enthusiasts/catalog_item_detail.asp?catalog=8729&levelcode=23722&product=1560844&cattype=&ProductCategoryCode=
2. Reversed lights
http://www.radiantz.com/index1.html?c34.html&1
3. Under-drive-pulley
http://www.conquestcustoms.com/Underdrivepulley.aspx\
4. New handle bars 1 ¾ Inch
http://www.burleighbars.com.au/
5. Brake away (cruze control )
http://www.brakeawayproducts.com/appguide-5CP02-static.php
6. Motorbike camera
http://www.4kam.com/bike_camera_motorcycle_cam_packages.htm
7. Front tire
8. Rear rim 10” or 10.5” for 300 mm tire
9. Skid Plate to fabricate, chromed maybe ?? cool looking
http://www.victorymotorcycles.com/en-us/community/story/vision-8-ball-cruisers-coast-ride
10. Clutch & clutch cable etc
http://www.barnettclutches.com/
11. Blue filter covers for K&N
http://www.outerwearsracing.com/default.asp
12. Handles of controls / led etc
http://www.customvictorychrome.com/
Soon as a mate buys the 250 Ninja, next week he reckons..
a rear Night Dragon 180 55 18
and a front one...OR...dada!!!...well that XC front wheel I bought a while back, done another tape measure run and I reckon it'll fit the front of my Vegas, just swapping over my brake rotor off my 21"
measures same 170mm bearing outer to bearing outer, and will give me more front rubber on the road (it's got a brand new E3 on it)
A different stance and look and feel altogether and it'll save me buying a 21" front tyre.
Think I'll need to lift the front fender up a bit to clear the wider 120 tyre but.
Also may buy a better rear shock.
I'm happy with the rest!.....simple:)
or if n' when my Vegas sells then I'll purchase and hot up a CrossRoads to my specs.
The next thing for my Jackpot is to take off all the stuff I put on to make it more comfortable for longer rides and put back on all the good looking stuff. Going to lose the Kuryaken iso grips and swing wings and add back the chrome ones. I already removed the touring seat and put the solo seat on. I also need to get rid of the front turn signals and install the mbw wrap arounds I have. And while I am swapping out the grips I'll put the 1/4 turn throttle on as well. Looks like I have a few winter projects ahead of me.
What I'd really like to do but don't currently have the time or money for would be to add the kewl metal 45° rake and a conquest back end. Maybe one of these years. Now that I have the Vision I can take the comfort stuff off. I've already put a lot into the Jackpot and am looking forward to putting it back to a badass cruiser instead of the touring bike I've used it for. :D
Edit: oh yeah, get rid of the stock mirrors and put the rad III's back on!
Custom cycle hand controls, lve been waiting more than a year for them and some custom bars to suit. Just waiting for them to get my accutronix grips to modify to suit there controls , so not long now. And finally a Dakota digital dash cluster would top it off just nice
Paul waiting for your video on the 1/4 ring I tried to install mine and got frustrated, so I hope you install yours fast and share the video
i just ordered touring lowers for mine so next up is either cams or a trunk
1 - 15 of 15 Posts
