1 - 5 of 5 Posts
I have an AFR meter with a single sensor. Which cylinder should I monitor? front or rear?
Front cylinder most likely runs a bit cooler, and the rear a bit warmer. Which gives a better indication of the running condition?
Thoughts?
m
I would start with the rear cylinder since it is hotter. I would switch it back and forth every so often to get a good idea how both cylinders are running...
WHOUW
that is amazing "Afrplus.com" nice gadget.... anybody installed this already on there VIC??
So if you running a Power V + timing + Torque tubes + AVI + etc.. then you could actually see on this device if your engine is running "good?" and should or should not change your downloaded map??
PS a lot of cables to install tough????:D :crzy:
1 - 5 of 5 Posts
