1 - 13 of 13 Posts
I have ones kind of like that in the high beam and I had to reverse the heat sink to make it fit. These don't look like they have a
screw on heat sink unless I missed it.
What I read about the low beam is you have to move the wiring harness behind the headlight for the LED's to fit.
Keep doing some research. Not sure they wrong but you have to add a load resistors for each bulb. I'm sure there is something out there.
I just changed my H-4's cause one burned out and I would of done LED's but wasn't for sure witch ones to do.
Write this guy he used to have ones for vision and maybe he can give you a answer
Zen Cart!, The Art of E-commerce
Load resistors are for turn signals not headlights.
I stand corrected his vision does take those bulbs. To be honest I didn't even notice he had a vision.
led
I put LED in my victory years ago. I got them from a friend who owns Cyclopsadventuresports.com Excellent lights and now has even brighter ones which im going to install on my trophy as my halogens have failed already. it was a bit of a job to get them installed but well worth it in my opinion. Les
1 - 13 of 13 Posts
