1 - 4 of 4 Posts
Yes and No
The stering stem on most all h-d springers is longer then our necks. So you would have to make a spacer of some sort. Or if your lucky and the springer has a removable stem you could get one made.
By the way a springer front end doesn't really give a good ride
Yes and No
Thanks, I did a little more research and found that there is one out there made by paughco that is suppose to be a direct fit, but it is wat more than the ones made for Harley. Will have to put it off for a while longer.
http://www.paughco.com/2008-catalog/pdf/SECT01-springers.pdf
Thats a lot of money for a front end that doesn't work that well.
Take your time and think about it. Find some h-d riders and see what they can tell you
1 - 4 of 4 Posts
