1 - 15 of 15 Posts
I am looking for a shorter windshield for my Cross Country Tour. From what I can see the only one that uses the stock brackets is the 7JuRock. The other choices are getting Madstad brackets. MY question is do any of the other windshields that mount with the smaller brackets sit on the outside of the fairing like the stock tour windshield.
I have a CCT and settled on the 7JRock and couldn't be happier. I got the 14" smoked slipped shield. I'm 6'1". With the stock seat the top of the fairing comes to just below my nose.
The brackets that come with the Tour have six bolts to hold its extra-tall stock windshield in place. Those brackets, in turn, bolt to the bike's metal (underneath the curved black plastic part) with four bolts. All you have to do is remove the Tour's windshield and those special brackets, set them on the shelf, and you have -- for windshield purposes -- an XC, instead of an XCT. That is, a vast array of aftermarket windshields meant for the Cross Country will now bolt directly to your Cross Country Tour.
I knew from sitting on the bike and demo rides that I did NOT want the stock Tour setup, because I'm a look-over, not a look-through, rider. So when I ordered my XCT in 2012, I had the dealer put on a KlockWerks Flare, instead of the stock XCT brackets and barn-door windshield. (The bikes come crated without any windshield on, so the dealer has to do prep work. I had to pay for the Flare, but no labor.) I put the XCT brackets and windshield in the car, my wife drove home, and I rode the bike home. (I later sold the brackets and windshield, and bolts and washers.)
In addition to 7Jurock and Madstad, and Klockwerks, you can get windshields for the XC/bracketless-XCT from Vic itself, Gustafsson Plastics, Clearview, Cee Bailey, and some others that escape me at the moment.
The Flare I had (and sold) fit behind the upper fairing edge. The Madstad (that I now have) sits above the fairing. I'm not sure why you're concerned about how an aftermarket windshield fits. Much more important, IMHO, is how a given windshield affects buffeting and how it provides protection or cooling. That, in turn, will depend on how tall you are, your torso length, what kind of helmet you wear, what kind (if any) lowers you have, and so forth.
FWIW, I thought the KW Flare looked nice and worked well for my 5'9", 30"-inseam, height, but not so well for shorter or taller riders. I have an 11" Madstad and their brackets, which is adjustable and works well for me, too, but a lot of folks think they're fugly.
We are about the same size. I am not too concerned about if it fits in front of or in the fairing edge as far as function more of a preference and ease of installation thing if I ever want to use the big windshield again. Thanks for your input it seems that you have gone through a few shield. You are right the Mastad is fugly but it seems people love it as far as performance.
I'll be another to tout the performance of the Madstad. I have 2 infact, one on my XCT and the other on my wife's Magnum. I'm about 5'8" and using the low seat with the Madstad 9". I'm more than pleased with it and would absolutely do it again. Wife wanted just a bit higher and has the 11" on hers, but either way, protection and lack of buffeting is excellent.
Well, the esthetics of the Madstad doesn't bother me, or maybe I'm just used to it. And I have a lot of other black stuff on my XCT -- trunk rack, handlebars, mirrors, and levers, for instance -- that I feel it kind of blends in. See pic.
With whatever XC-compatible windshield (or windshield + brackets, in the case of the Madstad) you go with, changing back to the stock XCT configuration is still just a matter of removing four bolts, and then installing ten bolts (four to put the XCT brackets back on, and six to attach the tall windshield to them). Not a big deal.
Incidentally, I replaced the four hex button-head bolts that attach directly to the bike with socket-head bolts (M6 x 16mm). I messed with these bolts enough that I got tired of buggering the heads if a hex key wasn't inserted exactly at a right angle. See other pic (and the other stuff in that pic is part of a homemade system of brackets and tube I made, to mount a GoPro in the middle of the bike, behind the windshield).
I am just a little ways south of you in Keller and would be happy to show the Baggershield I have on mine. I have a v-stream blade and a Klockwerks flip packed up in the garage. If you want to come see them I would be happy to help you put one on to try it out. I will sell either at a reasonable price if it works for you.
Thanks for the pictures. Do you have a picture of the Madstad from the other side so I can see the mounting system. Bill posted one but it has a homemade bracket so I am not sure what it looks like stock. I am a little anal retentive about looks but from the front it doesn't look bad. Bill thanks for the pictures also.
Mike sounds like that may be a good plan. What is height of the VStream?
My pleasure. I have a bunch of pics of the rider's side, in a sub-gallery I have of my Heli-Bar installation. Take a look at the last few pics in that gallery, starting here -- Victory XCT HeliBars Installation -- and see if that helps.
Get a CeeBailey's Windshield and be done with it. You can have it custom sized to any height and they are HIGH QUALITY shields.
Its only like 8 inches...it looks great but is too low for me at 6'3". The Klockwerks is I think 14".
Oh...and I've owned a Madstad setup before. Some people love them, and some not so much. I was one of those that didn't care for the system...it's quality made, but it's obtrusive and is pretty dog ass ugly on the bike.
Discussion Starter #13
I think we have a too high on one and too low on the other situation. I am 5'9" I was thinking somewhere between 11 and 12" would work for me.
Sitting in a normal riding position, level off the tip of your nose, and mark the stock shield with tape. Measure from the top of the cut out to the tape. 7jurock will custom cut what you need. I'm 6'3" and ride a 14" flip. Very happy with 7jurock!
Discussion Starter #15
Thank you for the advice. This is my first bike where I will have a windshield on it for over two weeks. I guess I am just getting old.
1 - 15 of 15 Posts
