1 - 6 of 6 Posts
okay, now i see the issue here, the mirror mounting positions on the housings are different left and right side, and what works on the left doesnt adjust high enough on the right side to see . anyone discover a solution?
I think you can use an extension for the shorter one. Hopefully someone else can provide better feedback.
Kuryakyn has mirror extensions or you could go to Dennis Kirk and look threw 400 different mirrors and buy new ones.
I solved that by installing the hydraulic clutch lever kit. A side benefit is that the cable will not break now :)
thats a common road i go down broggyr, buy a 100 dollar part and to get it to work i buy a hydraulic clutch. thanks for the heads up...
its the housing angle that is off. look at your mirror mounting positions, they are different left to right. that is the cause. xc owners should be notified that these wont work on a cross country unless you are a pigmy or they change the mounting hardware.( also need to shorten the adapter so its not so noticible...)
1 - 6 of 6 Posts
