1 - 20 of 26 Posts
Apparently, Stebel is out of business so I guess I won't be getting a Nautilus Air Horn. Does anyone here know anything about the WOLO Bad Boy Air horn? I did a forum search for this but came up empty.
You still should be able to find one; even if they went out of business there are most likely 100's available on the internet.
I ran a Stebel horn on my Road Glide a few years back......It lasted 6 months (if that). Between the heat and vibration, the plastic dried out and basicly came apart. Loved it when it worked, returned to factory horn when it came apart on a road trip leaving me without a horn at all and almost hitting the bike behind me at freeway speeds........maybe thats why they are no longer in buisness?
Anyway, just my experiance with them.
Had one on my last bike for a few years with no issues.
Harbor Freight Tools has them.
The WOLO Bad boy is constructed exactly the same as the stebel. You can still find them at your local Vato-Zone and O'Reemlies.
stebel air horn ? It may be built to only last a few years but its loud and worth every bit I paid for it..let us know how the bolo is if you get one..
Have one in each of my 4 wheelers (in addition to the stock horns) and they have lasted many years so far.
I just got the Wolo Bad Boy at Harbor Freight for that same price a couple of weeks ago. It works great. I installed it under the faring with a small bracket I made. You can install it by itself or in line with the existing horn. I did the latter because it was less wiring. Just a extension of the positive and negative from the horn under the chin faring on my bike.cheers
I do believe the OEM horns are already on a relay, so no additional one is needed.
Has anyone installed a Wolo Bad Boy or Stebel on a Jackpot? If so, where did you put it?
All vics or just the new ones?
1 - 20 of 26 Posts
