capacity in a 2000 v92 - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 02-08-2015, 09:57 AM Thread Starter
Default capacity in a 2000 v92
I bought a 2000 victory and the original owner told me it takes 7 quarts of oil. That sounds like too much to me but he explained it needs it due to the upgraded transmission. Is that possible? I'm hearing it is way too much oil and pistons will be floating in it.
Briklayr is offline
post #2 of 4 (permalink) Old 02-08-2015, 11:17 AM
I believe it is 6 quarts. That is how many quarts come in Vic's 6 quart oil change kit for the older bikes. You should be able to download an owners manual for your bike from Vic's web site. That way you will have all the correct info.
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
post #3 of 4 (permalink) Old 02-08-2015, 12:12 PM
Ghost_Rider's Avatar
Holds 6 quarts. Bbob has free manuals you can download, I only saw the parts manual for your bike, but the 3rd or 4th page had all the specs on it, and it showed 6 quarts
https://www.victoryforums.com/showpos...40&postcount=1
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #4 of 4 (permalink) Old 02-08-2015, 12:50 PM
Briklayr
if you sing up on Vic web page you can view owners book at bottom of page.
When you check the oil it has to be straight up and down and screw the dip stick all the way in then out
http://www.victorymotorcycles.com/en-us/owners-manuals
