dam rear head gasket frekn leaking oil. is there a fix besides removing head etc. dam gaskets are approx 40 or so for 1 not to include labor.
crank case breather was first thing i checked. in the past it had came off the nipple under the tank.I was just think'n, could it be the Trans/Engine Breather? If some how pressure is building up an out thru those....
Hahahahahaha never heard that before.i could fuk up a steel bowling ball in a sand box.
Yeah what Vin said, I had same leak thought same as you.Maybe you've overfilled the oil and it's blow-by dripping down the rear cylinder.
as i told others that was the first thing i checked and thats not it.Sure sounds like a breather tube problem.
i might try to replace entire tube.Yeah what Vin said, I had same leak thought same as you.
But it was blowby running down in between the cylinders then hitting the ledge at the top of the barrel and running along and dripping off the back.
Had me fooled too for a while.
Don't go pulling anything down just clean the oil and don't add as much when you change it.
DO NOT sand anything.Thank you motorbiker X for your reply. It's really the front cylinder and it is definitely leaking from right under the exhaust at the gasket. I like your talcum powder trick like a fat girl on the wet spot. LOL. I'm at the point now since I've had this motor apart two times now trying to fix this and have done everything even take it to my local Harley guy and sand down The Jug and head check for tolerances and make sure the dowel pins are proper and a new gasket I'm either going to stuff some black RTV or JB Weld putty in there since no gases are escaping just oil after I shut it off has to be the top lip on the outside of the gasket at the oil runs down on from the head and then comes out
